Beta testing: Remote Utilities for macOS/Linux
- https://www.remoteutilities.com/product/release-notes.php#macos
- https://www.remoteutilities.com/blog/remote-utilities-v7.5/
- https://www.remoteutilities.com/download/mac.php
- https://www.remoteutilities.com/download/linux.php
- https://www.remoteutilities.com/about/blog/Remote_Utilities/viewer-for-mac-linux/
- https://www.remoteutilities.com/support/docs/security/#Authorization
- https://www.remoteutilities.com/support/docs/security/#Single_password
- https://www.remoteutilities.com/support/docs/security/#Remote_Utilities_security
- https://www.remoteutilities.com/support/free.php
- https://www.remoteutilities.com/support/docs/registering-the-program/
- https://www.remoteutilities.com/support/forums/forum11/1399-viewer-for-mac-and-linux-_-beta-testing?
- https://www.remoteutilities.com/support/kb/what-is-a-direct-connection/
- https://www.remoteutilities.com/support/kb/what-is-an-internet-id-connection/
- https://www.remoteutilities.com/support/docs/host/
- https://www.remoteutilities.com/support/docs/file-transfer/
- https://www.remoteutilities.com/about/eula.php
- https://www.remoteutilities.com/about/support-policy.php
- https://www.remoteutilities.com/support/docs/terminal/
- https://www.remoteutilities.com/buy/upgrade-form.php
- https://web.archive.org/web/20220324124107/https://www.remoteutilities.com/download/linux.php
- https://www.remoteutilities.com/buy/sales-inquiry.php
- https://www.remoteutilities.com/support/forums/forum11/2496-host-agent-for-linux-alpha-preview
- https://www.remoteutilities.com/support/docs/editing-connections/#Additional_properties
- https://rentry.co/remotemacos/raw
- https://packages.debian.org/
- https://www.remoteutilities.com/download/host1.0.23.b23.tar.xz
I just installed RU Host on a Linux Mint machine. Two hopefully quick questions:
1) There's no option to configure 2FA - is that feature Windows-only at present?
2) Whenever I move the mouse, type, or interact with the RU connection to the Mint machine, I get occasional screen tearing/jagging/flickering. I installed the X11 feature that was called out during the RU installation. Do I need to do anything else to stop the flickering?
Hello MP,
If you mean something else, please let us know.
Yes, unfortunately, the 2FA feature is not available in the beta version for Mac/Linux yet. However, it should be available in the final release of the stable version along with the rest of the features.There's no option to configure 2FA - is that feature Windows-only at present?
Could you please clarify if you mean the Nextgen codec? If this is the case, could you please make sure that both Host and Viewer are updated to the latest available version?Whenever I move the mouse, type, or interact with the RU connection to the Mint machine, I get occasional screen tearing/jagging/flickering. I installed the X11 feature that was called out during the RU installation. Do I need to do anything else to stop the flickering?
Is there a binary/package for arm64 available please? (for Raspberry Pi)
Hello Mike,
Unfortunately, currently there’s no installation package specifically for arm-based systems. However, we do plan adding support for ARM Mac/Linux OSs in our future releases.
Jason Carr,
Dec 11, 2025 11:32:00 am EST
I am running into "Dependency resolution failed" on attempting to install on a clean install of Debian 13. I was able to install the libxcb-icccm4-dev (the others weren't found), and am still receiving the same error. Is there a way for me to get info on which dependencies are missing, like a command line install path?Pauline wrote:
Hello Michael,
It seems the libxcb-icccm package is missing from your system’s repositories. Here are a few steps to try:
1. Update Your System :
Try running the following commands to update your package list:sudo apt update2. Install an Alternative Package :
sudo apt upgrade
Try installing libxcb-icccm4 or libxcb-icccm4-dev instead:sudo apt install libxcb-icccm4 libxcb-icccm4-dev3. Manual Installation :
If the package is still unavailable, you can try downloading it from Debian Packages and install it manually:sudo dpkg -i <package_name>.debAfter completing these steps, try running r-agent again. If the issue persists, please let us know your exact OS version and any error details.
Jason Carr,
Dec 11, 2025 12:16:31 pm EST
DUPLICATE POST REMOVED
Edited:Jason Carr - Dec 11, 2025 4:23:36 pm EST
Support (Posts: 3206)
Dec 29, 2025 12:10:54 pm EST
Dear users and beta testers,
We have released the first beta version of Remote Utilities Host for macOS. Feel free to download and test it — we appreciate your feedback.
P.S. The version number is beta 23 so that it matches the rest of the macOS and Linux modules.
Jim Tracey,
User (Posts: 29)
Dec 30, 2025 7:52:36 pm EST
I successfully installed and connected to the macOS host, but could not access extended monitors from Viewer on Windows, just the main one. Is this a current limitation of the Beta, or did I miss something?
Thanks for your continued efforts.
Dec 31, 2025 3:19:53 am EST
Hi Jim,
Thank you for the feedback. Unfortunately it's a current limitation of the beta version.
Jim Tracey,
User (Posts: 29)
Jan 01, 2026 3:45:37 pm EST
Hi Conrad,
Understood, thanks. I've just discovered that if the remote mac screen goes blank (sleep) RU does not wake it. I tested this from both Android and Windows.
Thanks,
Jim
Thanks,
Jim
