- https://www.remoteutilities.com/test/viewer_2019-12-20.zip
Just wanted to confirm that the 6.12 beta has fixed all of the issues reported here. Many thanks
2460 WH 94,
Apr 22, 2022 9:00:58 am EDT
Hi,
Had the problem for the very first time 3 days ago. Solved it by uninstalling various .NET framework updates (KB5012117, KB5010472) and preventing them to be reinstalled by using the "wushowhide.diagcab" tool from Microsoft.
I hope this will help !
Dave Pavlicek,
Jul 25, 2022 5:24:35 pm EDT
This problem just cropped up for me. My guess is you guys glued down this issue and Microsoft through .NET update unglued it for you. I'll keep this thread subscribed to see if you guys are able to glue it down again.
Dave
Dave
Hello Dave,
Could you please try updating both Host and Viewer to the most recent version 7.1.5.0 and see if this helps to fix the issue? You can update your Host and Viewer using the Simple Update feature. In addition, please make sure that your Host and Viewer are both updated to the same version and there's no version mismatch because it might lead to some features not working or other performance issues.
Dave Pavlicek,
Jul 26, 2022 3:50:31 pm EDT
We are running 7.1.5.0 on both the viewer and the host. Today the system works fine. This seems like a fun bug to trace down.
Dave
Dave
John Stevens,
Jun 04, 2024 11:42:41 pm EDT
This issue just started for me a few days ago.
The suggestion from five years ago to "Stop the process Microsoft Office Click-to-Run Update Support" successfully resolved it.
Running 7.2.2.0 on both viewer and client.
Client is Win11
Viewer is Win10
Client is Win11
Viewer is Win10
