Tailscale will it work with it
Support level: Plus
Has anyone been able to use Taiscale with remote utilites ? I know it works with rustdesk by using the DIRECT IP option but what about remote utiltes does it have a Direct ip option?
Hello John,
Remote Utilities does offer direct access to the remote Host machine via Direct connection using Host's IP address. For more information on how to set up Direct connection please see this page.
Support level: Plus
That was easier than I thought you don’t have to be on the same subnet because tailscale places all those devices in your tail making them easy access and secure from one to another ,, Just tried it and works Great ! thanks even better since the traffic does not go thru your servers...Thank You!
Edited:johnran - Jul 28, 2025 8:20:58 pm EDT
Support level: Plus
Support (Posts: 3182)
Jul 29, 2025 6:15:30 am EDT
Support level: Plus
Yeah, unfortunately that does not work.. Until you log in then log offConrad Sallian wrote:
Hello Johnran,
You might want to try enabling checking online status for direct connections and see if it helps. This option is in connection properties.
Then if you close out the Viewer and openit again it will still show Unknown and greyed out.
..wait it tool about 1 minute but it DID work
Wonder why it took so long
Edited:johnran - Jul 29, 2025 1:10:16 pm EDT
Support level: Plus
Thank you fo ryour help works great with tailscale and takes the burdon off your servers I m sure Plus makes it extremley secure from endpoint to endpoint..! thanks
Jul 29, 2025 3:00:05 pm EDT
Hi John,
It took a bit longer because this feature only sends keep-alive requests about once a minute. It was designed this way to avoid clogging the network in environments with hundreds of thousands of PCs.
