Remote Sound is loud static
Using the newest host and viewer 6.9.4.0. The remote sound is a very loud static sound. You can barely hear some (very little) of the original sound within the static, but it mostly sounds like a radio tuned to a station that doesn't exist and turned all the way up.
These are Windows 10 computers.
Support (Posts: 3243)
Dec 22, 2018 5:48:29 pm EST
Hi Jack,
I'm sorry, could you please clarify what you mean by static sound? Is it some sort of a permanent noise or else?
It is a loud static only while there is a sound file playing. For example, if I play a 3 second audio file, there will be loud static for 3 seconds. Or, if I change the volume on the host computer (you know there is that 1-second ding sound when you change the volume by the clock, the remote computer will have a loud static sound for 1 second instead of the ding sound. If I try to play a video on the host, the remote will have a loud static sound as long as the video is playing.
Dec 26, 2018 5:44:50 am EST
Hello Jack,
It could help to see a screenshot of your speakers properties. Please, refer to this forum thread, the second page.
