File transfer: can not open folder RTU version 7.0.0.01
g internetnono,
Mar 20, 2021 8:56:48 am EDT
Since Viewer version 7.0.01 file transfer doesn't work anymore (using Internet ID connection). The File taransfer window shows OK, at left the local folders, at the right just blanks whith popup message 'Can not open folder'. Entering a drive letter and folder name gives no result. So I cannot use File Transfer.
Hello! This is expected behavior if your Host is running a 6.x version and your Viewer is 7.x. Update the host to use the same version as your Viewer and you should be good to go!
https://www.remoteutilities.com/blog/remote-utilities-7-release/#File_Transfer_navigation_speed
Jimmie Noble,
Mar 20, 2021 1:26:03 pm EDT
Where do I find the version number of the host on my computer?
Support (Posts: 3184)
Mar 21, 2021 3:32:00 am EDT
On the Host computer - right click on the Host icon in the system tray and select "About Remote Utilities".
You can also check the Host version remotely from the Viewer side. In Viewer switch to Details view (View -> Details) and check the "Version" column. For this method to work you must log in to the remote Host at least once so that it can communicate its version number to Viewer.
