where can I find viewer ver. 6.10.9 (for windows)?
Hi all,
I urgently need the viewer ver 6.10.9 but on the website, older version page, I can find only 6.10.10.
thanks you all for your help
Support (Posts: 3210)
Mar 04, 2021 6:36:11 am EST
Hi Marco,
When it comes to the previous version we only provide the most recent version, which (for version 6) is 6.10.10.0
Hi Conrad and many thanks for your prompt reply!
ARGHHHHHH!!!!!
I have a little issue...
I should have to do a public request ;-)
someone have, casually, saved in his PC the viewer version 6.10.9?
please!
ARGHHHHHH!!!!!
please!
Mar 04, 2021 6:48:58 am EST
Hi Marco,
May I ask why you need version 6.10.9 whereas version 6.10.10 has more fixes and is overall more stable? :)
sure
I have one remote PC installed with host 6.10.9
my viewer is 6.10.10 and if I go trying to access remote settings it gets me the error that host and viewer haven't the same version
I could upgrade that host, but there is nobody near that PC, then if something goes wrong for some reason, I would be out of the game....
ARGH!
ARGH!
nobody kept or saved that version?
;D
;D
many thanks Dimitri for your post! really appreciate that!
unfortunately when I click I land on a "403 forbidden" error page
maybe some rights to be settled up on that file?
Hi Marco, probably a country restriction, try this link:
viewer6.10.9.exe
viewer6.10.9.exe
Hi Dimitris, thank you!
I donwloaded right now!
thank you very much!!!
