CONFUSED ABOUT INSTALLATION
KELLY CUNNINGHAM,
Jan 14, 2019 10:50:57 am EST
I want to install this program so my computer can connect to a desktop. Would the desktop be the host?
Support (Posts: 3210)
Jan 16, 2019 4:40:07 am EST
Hello Kelly,
Yes, the remote computer which you want to access should have Host installed. The computer you work from should have Viewer installer.
https://www.remoteutilities.com/support/docs/host/
https://www.remoteutilities.com/support/docs/viewer/
Steen Kristiansen,
Feb 03, 2019 5:14:59 pm EST
Feb 04, 2019 9:43:38 am EST
Hello Steen,
Thank you for your message. Couple of questions:
1. Do you use the latest version of the program? The latest version as of this writing is 6.10.3.0.
2. What actions produced this result? Can you reproduce this issue again?
Steen Kristiansen,
Feb 04, 2019 4:20:14 pm EST
Hallo Conrad
I have found out:
Delete the file config_4 in app. data and install again.
I have found out:
Feb 04, 2019 4:23:08 pm EST
Hi Steen,
Yes, that works as a workaround. I was just hoping that if it was a bug we could find a cause and possibly fix it :)
Anyway, let us know if you need any assistance in the future.
