Hi!
I just started using Remote Utilities and already have such problem.
I have two computers in different networks: computer "A" and computer "B". Both have Windows 10. Both are behind NAT.
I installed Host 6.10.9.0 and Viewer 6.10.9.0 on both of them.
On the computer "A" I see the computer "B" as yellow and "Online". I press "Logon" and get successfully logged on to it.
On the computer "B" I see the computer "A" as yellow and "Online". I press "Logon" and it immediately becomes grey and "Offline". I see 5 unsuccessful attempts to connect and that's all. After a while the computer "A" becomes yellow and "Online" again, but trying to connect to it has the same effect.
In the event log of the Viewer on the computer "B" I see:
26-06-2019__16:21:46__026 Connection #710114. Connection to "***-***-***-***". Mode: <Authorization>. Connecting...
26-06-2019__16:21:46__057 InetConnection #710114. Internet connection to ***-***-***-*** (id.remoteutilities.com:5655).
26-06-2019__16:21:46__071 InetConnection to internet-id server #710114 Error. Name: "***-***-***-***", host: "id.remoteutilities.com:5655". Exception class: "EIdSocketError". Message: "Socket Error # 11001
Host not found.".
26-06-2019__16:21:46__077 InetConnection to internet-id server #710114 Error. Name: "***-***-***-***", host: "id.remoteutilities.com:443". Exception class: "EIdSocketError". Message: "Socket Error # 11001
Host not found.".
Host not found.".
26-06-2019__16:21:46__094 Connection #710114. Connection to "***-***-***-***" failed. Mode: <Authorization>.
(***-***-***-*** is the computer "A" Internet-ID)
I downloaded portable Viewer to the computer "B" and it successfully connects to the computer "A", so it seems this is not some network problem on the computer "B" or the computer "A" but some problem of the installed on the computer "B" Viewer.
How can I fix this problem?
