Remote Connection Window is Very Small
Amy Chaplin,
Jan 04, 2019 7:59:39 am EST
Support (Posts: 3205)
Jan 05, 2019 5:54:25 am EST
Hello Amy,
Does the maximize window button work? I mean the second screenshot with the Full Control window.
Amy Chaplin,
Jan 11, 2019 8:47:39 am EST
Jan 11, 2019 8:57:58 am EST
Hello Amy,
This is because the resolution on the remote computer screen is lower than the resolution on the Viewer screen, and you are viewing the remote desktop "pixel-for-pixel". You should enable the stretch mode to fill the entire desktop on the Viewer side.
Right click on the connection item in the address book, select Properties -> Modes -> Stretch.
Note, however, that this way you are simply stretching the image, not adding more pixels (graphical information) to it. So the image may not look as crisp as you would expect if the remote resolution were the same as the local one.
Darrin Mulligan,
Feb 14, 2022 9:50:38 pm EST
I resolved a issue with the window opening to a very small size by standardizing all the session display settings. It appears that having one session set with a 24bit / FPS setting would resize all to a small window. Standardizing all sessions on 16bit / Normal resolved my issue.
