Remote Utilities on Ubuntu with Wayland
New Remote Utilities for macOS and Linux: Wayland support with unattended access. Learn more →
Remote connection hangs after a few minutes
I installed Remote Utilities Host and Viewer so I can remotely login from work/home to home/work.
I can connect fine (Full Control) but after a few minutes the connection hangs and I can only see the desktop but cannot select anything.
I don't see any other way to reset the connection than closing it and reconnect again. Then after a few minutes it hangs again.
What could be wrong?
P.S. I had no such issue with T V.
Edited:Paul Dubé - Aug 07, 2018 11:09:12 am EDT
Hello Paul,
I recommend that you check antivirus software on the remote computer and add Remote Utilities - Host to a/v software exceptions. This article can help https://www.remoteutilities.com/support/kb/remote-utilities-is-mistakenly-detected-as-malware/
