Remote Connect without display do not function
Hello Markus,
Please make sure that your graphics card driver is already updated to the most recent version available. In addition, please make sure that the remote Host machine was restarted after enabling the Legacy Capture mode feature in order for the changes to be applied.
Last but not least, please try the solutions listed in this troubleshooting guide and see if any of them might help to resolve the issue.
Let us know if this helps.
Markus Rüb,
Jan 29, 2024 1:11:32 pm EST
Thank you. - I will try this...
Can you delete the Product-key in my first message? Thank you ;)
Hello Markus,
Unfortunately, I wasn’t able to edit your first message, so I hid it from the forum instead, so it’s not publicly available and only visible to you.
Let us know if the issue persists or if you have more questions.
Support (Posts: 3196)
Jan 29, 2024 1:17:35 pm EST
Hello Markus,
We've updated the message. Please, do not share your sensitive information publicly on the forum. If your support request contains such information, please use the ticketing system. Posting on the forum will not speed up the response (quite the contrary - the tickets are usually responded faster than messages in the community).
