Error update to 7.0.2.0
Support (Posts: 3210)
Jun 20, 2021 1:08:46 pm EDT
Hi Conrad,
Thanks for your answer.
I can't uninstall Viewer because I get the same error from the image in my previous message: .msi file is missing
Also, do I lose my free license when Viewer is uninstalled?
Thanks greetings.
Thanks greetings.
Jun 21, 2021 6:39:22 am EDT
Hello Pedro,
This is an issue with MSI installer on your computer. Please, try this fix tool from Microsoft:
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-removed-cca7d1b6-65a9-3d98-426b-e9f927e1eb4d
Hi Conrad,
It has worked! Thank you very much, I already have Viewer 7.0.2.0
I keep the Microsoft utility in case I need it for another program ...
You can consider the problem solved, thank you, greetings.
