RDP using custom port other than 3389
hello and thanks for reading this,
rdp over remote.utilities is a killer feature. from what I can see it uses ssh tunneling or stunnel.
for security reasons, I always change the default rdp port from 3389 to something, as per this registry entry
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal­Server\WinStations\RDP-Tcp\PortNumber.
I guess the remote.utilities does not check for the correct port number.
so is there a way to get remote.utilities to use a custom port number?
also, how can I customize the rdp settings, such as screen size, full screen, smart scaling, etc.
is there a way to use a .rdp file
thanks much,
david
please ignore my port, I figured it out.
thanks
Hello David,
I'm glad to hear you figured out the port issue.
To customize the RDP settings please do the following:
1. In the main Viewer window right-click on the Host icon and choose Properties.
2. Go to the tab Connection -> RDP.
3. Click Configure.
4.  The native RDP window will open where you can customize the connection settings.
RDP using custom port other than 3389 - 15 Mar 2019 03:10:39
Unfortunately, the RDP mode in the Remote Utilities doesn't allow to open .rdp files. To customize the connection settings, please follow the steps above.
