Noticed a connection that i didnt start. Checked logs and saw this.
Alex Alexander,
Dec 22, 2018 2:34:09 am EST
Should i be worried if i have never connected a computer and these are my logs??
Remote Utilities – host log
© Remote Utilities LLC. Version: 6.9.4.0 (69014)
Date (UTC) Code IP Event Info
03.12.2018---18:48:04:931 110 The new certificate was generated.
03.12.2018---18:48:05:004 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
06.12.2018---02:31:25:456 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
06.12.2018---15:17:17:887 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
08.12.2018---01:29:35:443 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
09.12.2018---22:31:22:296 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
10.12.2018---06:33:24:525 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
17.12.2018---23:44:28:870 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
19.12.2018---05:10:01:510 34 Remote Utilities - Host 69014 is started. GMT-06 Windows 10.0 64bit
Support (Posts: 3194)
Dec 22, 2018 5:42:04 pm EST
Hello Alex,
This line only means that the Host (the program itself) has started on the remote computer and is awaiting incoming remote connection.
If there were any connection (session) in place there would be a line mentioning the specific connection mode used, such as Full Control, File Transfer etc.
