Hello David and Peter,
Peter, thank you for your input. This is correct, I apologize for overlooking this in the David's original message.
David, unfortunately, Peter is right - there is a known bug in the version 6.12.2.0 Beta 2 when used on Windows XP, which prevents Viewer running on Windows XP machines from connecting to remote Hosts (you might receive "Access denied" error). However, this issue was already fixed by our developers and will be implemented in our next update which we hope to release very soon (approximately, by the end of this year, but hopefully, even sooner).
One more thing - could you please also try enabling the
Capture alpha blending windows feature in
Connection properties -> Additional Properties tab and see if this helps to resolve the issue with Windows menus?
So the answer is no, there is no manual screen refresh. Maybe this could be a future addition.
I am also not sure whether the Beta viewer will run on XP.
Yes, unfortunately, the only other solution here is to wait until we release our next update with the implemented fix for WindowsXP machines - then you should be able to update to the latest version and see if this helps to resolve the issue. We will make sure to notify you in this thread as well as soon as the new version is released. Sorry for the inconvenience.
When using remote install, should the viewer should be updated first or last. ( 2 viewers and 2 hosts).
When using Remote Install Tool feature, you should always update the Viewer first. Actually, updating Viewer first is recommended, regardless of the update method chosen to update the Host. For more information on updating via Remote Install Tool please see this
page.
