Windows Tablet
Dear Technical Support
I am e free user of Remote Utilities. The way application works is diffenetely it a tool i very much like to use for my company
But there is a important problem with application which is effecting that i can not use it fully.
I hanging tablet on wall and i need to hang as to to bottom, and in this case the client display is not responsing action, is i seen bottom of client display on the top of my screen and is makes inpossible to use it.
Would you guys do some updates for that, i very much like to buy a fully version as soon the problem is solved.
I can sent some screenshots if is nessesary fo you to se what i mean.
Support (Posts: 3210)
Oct 29, 2015 5:35:19 pm EDT
Thank you for the kind words.
Yes, please send us the screenshots. Not sure we understand the issue exactly.I can sent some screenshots if is nessesary fo you to se what i mean.
The free version is no difference from the paid one, except for the 10-PC limitation.Would you guys do some updates for that, i very much like to buy a fully version as soon the problem is solved.
