[ Closed ] [Resolved] Tailscale will it work with it
Has anyone been able to use Taiscale with remote utilites ? I know it works with rustdesk by using the DIRECT IP option but what about remote utiltes does it have a Direct ip option?
Hello John,
Remote Utilities does offer direct access to the remote Host machine via Direct connection using Host's IP address. For more information on how to set up Direct connection please see this page.
That was easier than I thought you don’t have to be on the same subnet because tailscale places all those devices in your tail making them easy access and secure from one to another ,, Just tried it and works Great ! thanks even better since the traffic does not go thru your servers...Thank You!
Edited:johnran - Jul 28, 2025 8:20:58 pm EDT
By the way the computer icons in remote utilites will look greyed out whenusing tailscale but they are still working if you try to connect. Because remote utiles does not see the private traffic..If you try it ..
Edited:johnran - Jul 28, 2025 8:31:35 pm EDT
Hello Johnran,
You might want to try enabling checking online status for direct connections and see if it helps. This option is in connection properties.
[Resolved] Tailscale will it work with it - 29 Jul 2025 06:15:13
Conrad Sallian wrote:
Hello Johnran,
Yeah, unfortunately that does not work.. Until you log in then log off
Then if you close out the Viewer and openit again it will still show Unknown and greyed out.
..wait it tool about 1 minute but it DID work
Wonder why it took so long
Edited:johnran - Jul 29, 2025 1:10:16 pm EDT
Thank you fo ryour help works great with tailscale and takes the burdon off your servers I m sure Plus makes it extremley secure from endpoint to endpoint..! thanks
Hi John,
It took a bit longer because this feature only sends keep-alive requests about once a minute. It was designed this way to avoid clogging the network in environments with hundreds of thousands of PCs.
