Help removing Remote Utilities Host 7.1.7.0
Michael Polak,
Nov 13, 2026 5:36:52 am EST
I’m trying to remove Remote Utilities Host 7.1.7.0 from my Windows laptop. The cached installer failed its signature check. Could you send me an official link to the signed installer for that exact version, or tell me how to safely uninstall it?
Support (Posts: 3324)
Nov 16, 2026 5:07:42 am EST
Hello Michael,
Thanks for your message.
You don't need the original installer to remove the Host. Windows Installer keeps a copy of the package a program was installed with, and uses it again to uninstall it. When that cached copy is missing or damaged, the uninstall stops there. We don't publish installers for older minor versions such as 7.1.7.0, but the fix doesn't need one.
To remove the Host:
Once neither the folder nor the Usoris key exists, the Host and all of its settings are gone. The steps are also in our uninstall guide.
Let us know how it goes.
To remove the Host:
- Run Microsoft's install and uninstall troubleshooter. Choose Remote Utilities - Host when it asks which program, and follow its prompts. It clears the broken installer registration, so the program can be removed without its package.
- Delete the folder C:\Program Files (x86)\Remote Utilities - Host\ (C:\Program Files\Remote Utilities - Host\ on 32-bit Windows), if it is still there.
- Open regedit and delete the key HKEY_LOCAL_MACHINE\SOFTWARE\Usoris\Remote Utilities Host\, if it is still there.
- Restart the laptop.
