Creating Custom Hot Key Combination (Ctrl + Shift + 0)
Is it possible to create a custom hot key combination such as Ctrl + Shift + 0 using the Send Key menu in Remote Utilities or another way? I do not see an option for that specific combination and was wondering if it can be added or configured manually.
Hi Ashley,
Unfortunately, Remote Utilities doesn’t allow the user to assign custom hotkeys. Here’s a list of the hotkeys already available in Remote Utilities: https://www.remoteutilities.com/support/docs/viewer-options/
