Doesn't work on Samsung Galaxy SIII mini
Hi! Remote Utilities is a great tool, but unfortunately viewer doesn't work on Samsung Galaxy SIII mini phone (model number GT-I8200, Android 4.2.2). Application shows logo screen for 2 seconds and then exits without any messages.
Hello Michael,
Does restarting the device or re-installing the software from Play store work?
No, I'v tried both reinstalling and device restart, none helps (
Hi Michael,
Unfortunately, we can't help with this because apparently this has something to do with the underlying IDE /environment that we to build the Android app. I recommend you waiting till the next update of Android app.
Still doesn't work after last update.
Hello Michael,
I forwarded your report to our developers and asked for input. I'll keep you updated.
Michael,  could you please provide the version number of Remote Utilities app that you installed?
Hello! Sorry for delay. Android application - 11.12 as my phone shows in apps manager. Host - v.6.3.0.6.
Hello Michael,
We will try to reproduce the issue but there is a good chance that this issue is caused by the framework/IDE that we use. We will try to determine if that's the case.
