need help in blank screen
hello. Now I have problem when I turn the blank screen feature on it turn the screen blank which is great but when I set a Blank Screen Text nothing happens the text that I assign doesn't appear on the blank screen.
I am using the newest version for both the host and the viewer and the os of the pc which control the viewer is windows 10 and the os of the host is windows 8.1.
Need any Help
Hello Mohamed,
Unfortunately, the custom text/html/image option has been discontinued. The related controls in the Full Control window were left by accident, but we will remove it from the Viewer interface as soon as possible.
I am sorry if this made the program less useful for you.
When will this option work?
Hello Deividas,
Unfortunately, the Set text for blank screen feature has already been discontinued and we do not have plans for implementing it again. Sorry for the inconvenience.
Hello Deividas and Mohamed,
Just wanted to notify you that I have checked with our developers regarding the feature - we might re-add it in one of our future updates, perhaps in version 7 of Remote Utilities.
